3 MASTERFAN PRO 120 AIR BALANCE RGB WITH HYBRID-DESIGN FAN BLADE, SPEED PROFILES, AND CUSTOMIZABLE COLOR OPTIONS WITH RGB LED CONTROLLER BY COOLER MASTER
3 MasterFan Pro 120 Air Balance RGB with Hybrid-Design Fan Blade, Speed Profiles, and Customizable Color Options with RGB LED Controller by Cooler Master Type: Case Fan RPM: 650-1300 RPM +/-10% (PWM) Air Flow: 42.7 CFM Noise Level: Level 6 ~ 20 dba (max) Power Connector: 4 Pin Color: Black Package Contents: 3 Master Fan Pro 120 AB RGB LED RGB Controller 450mm RGB LED Extension Cable x 4 600mm USB 9 Pin Extension Cable x 1 Metal Screw x 12
Price: 84.99
© ® ™ 2017.
