AEROCOOL DS 140MM WHITE PATENTED DUAL LAYERED BLADES WITH NOISE AND SHOCK REDUCTION FRAME
AeroCool DS 140mm White 140mm Patented Dual layered blades with noise and shock reduction frame Type: Case Fan Bearing Type: Fluid Dynamic RPM: 1500 RPM+/-10% (12V) 1100 RPM+/-10% (7V) Air Flow: 93.4 CFM (138.1 m³/h) (12V) 71.2 CFM (105.9 m³/h) (7V) Noise Level: 23.4 dBA (12V) 15.5 dBA (7V) Power Connector: 3Pin with signal cable Color: White Compatibility: Case
Price: 24.99
