APEVIA 12L-CBL BLUE LED 120MM X 120MM X 25MM 4PIN PLUS 3PIN BLUE LED CASE FAN W - 30 X BLUE LEDS AND ANTI-VIBRATION RUBBER PADS
APEVIA 12L-CBL 120mm Blue LED 120mm x 120mm x 25mm 4pin+3pin Blue LED Case Fan w/ 30 x Blue LEDs & Anti-Vibration Rubber Pads RPM: 1500 +/- 10% RPM Air Flow: 57.67 CFM Noise Level: 24.7 dBA Power Connector: 3 / 4 Pin Dimensions: 120 x 120 x 25 mm
Price: 11.99
© ® ™ 2017.
