APEVIA 12L-CWH WHITE LED 120MM X 120MM X 25MM 4PIN PLUS 3PIN WHITE LED CASE FAN W - 30 X WHITE LEDS AND ANTI-VIBRATION RUBBER PADS
APEVIA 12L-CWH 120mm White LED 120mm x 120mm x 25mm 4pin+3pin White LED Case Fan w/ 30 x White LEDs & Anti-Vibration Rubber Pads Type: Case Fan RPM: 1500 +/- 10% RPM Air Flow: 57.67 CFM Noise Level: 24.7 dBA Power Connector: 3 / 4 Pin Compatibility: Case Dimensions: 120 x 120 x 25 mm
Price: 11.99
© ® ™ 2017.
