APEVIA 12L-DBL BLUE LED 4PIN PLUS 3PIN CASE FAN W - 15X ANTI-VIBRATION RUBBER PADS-RETAIL APEVIA 12L-DBL 120mm Blue LED 4pin+3pin Case Fan w/ 15x Anti-Vibration Rubber Pads-Retail Type: Case Fan RPM: 1500 +/- 10% RPM Air Flow: 57.67 CFM Noise Level: 24.7 dBA Power Connector: 3 / 4 Pin Color: Black Compatibility: Case Dimensions: 120.00 x 120.00 x 25.00mm
Price: 11.99
