APEVIA 312L-DBL BLUE LED 4PIN PLUS 3PIN CASE FAN W - 15X ANTI-VIBRATION RUBBER PADS - 3 IN 1 PACK - RETAIL
APEVIA 312L-DBL 120mm Blue LED 4pin+3pin Case Fan w/15x Anti-Vibration Rubber Pads (3 in 1 pack) - Retail Type: Case Fan RPM: 1500 +/- 10% RPM Air Flow: 57.67 CFM Noise Level: 24.7 dBA Power Connector: 3 / 4 Pin Color: Black Compatibility: Case Dimensions: 120.00 x 120.00 x 25.00mm
Price: 18.99
© ® ™ 2017.
