APEVIA 512L-CBL BLUE LED 120MM 4PIN PLUS 3PIN BLUE LED CASE FAN W - 30 X BLUE LEDS AND ANTI-VIBRATION RUBBER PADS
APEVIA 512L-CBL 120mm Blue LED 120mm 4pin+3pin Blue LED Case Fan w/ 30 x Blue LEDs & Anti-Vibration Rubber Pads Type: Case Fan RPM: 1500 +/1 10% RPM Air Flow: 57.67 CFM Noise Level: 24.7 dBA Power Connector: 3 / 4 Pin
Price: 29.99
© ® ™ 2017.
