APEVIA 512L-CMC 120MM X 120MM X 25MM 4PIN PLUS 3PIN DUAL RINGS CASE FAN W - 32X LEDS AND ANTI-VIBRATION RUBBER PADS - 5-PACK - 5 DIFFERENT COLORS BLUE - GREEN - RED - PINK - WHIT
APEVIA 512L-CMC 120mm x 120mm x 25mm 4pin+3pin Dual Rings Case Fan w/ 32x LEDs & Anti-Vibration Rubber Pads - 5-Pack(5 different colors blue/green/red/pink/white) Type: Case Fan RPM: 1500 +/- 10% RPM Air Flow: 57.67 CFM Noise Level: 24.7 dBA Power Connector: 3 / 4 Pin Compatibility: Case Dimensions: 120.00 x 120.00 x 25.00mm
Price: 27.99
© ® ™ 2017.
