APEVIA 512L-DMC 120MM 4PIN PLUS 3PIN CASE FAN W - 15X LEDS AND ANTI-VIBRATION RUBBER PADS, 5-PACK - 5 DIFFERENT COLORS BLUE - GREEN - RED - PINK - WHITE
APEVIA 512L-DMC 120mm 4pin+3pin Case Fan w/15x LEDs & Anti-Vibration Rubber Pads, 5-Pack(5 different colors blue/green/red/pink/white) Type: Case Fan RPM: 1500 +/- 10% RPM Air Flow: 57.67 CFM Noise Level: 24.7 dBA Power Connector: 3 / 4 Pin Compatibility: Case Dimensions: 120.00 x 120.00 x 25.00mm
Price: 27.99
© ® ™ 2017.
