BGEARS B-BLASTER 120X38 2 BALL BEARING HIGH SPEED 4500RPM WITH 218 CFM 120X120X38MM 3PIN 3WIRE DC FAN
bgears b-Blaster 120x38 120mm 2 ball bearing High Speed 4500RPM with 218 CFM 120x120x38mm 3pin 3wire DC Fan Type: Case Fan Bearing Type: 2 Ball RPM: 4500 RPM Air Flow: 218 CFM Noise Level: 45 dbA Power Connector: 3 Pin Dimensions: 120x120x38mm
Price: 14.99
© ® ™ 2017.
