EVERCOOL CLB9225-4LDI TRI-COLOR LED 92MM TRI-COLOR LED LIGHT CASE FAN EVERCOOL CLB9225-4LDI 92mm Tri-Color LED 92mm Tri-Color LED Light Case Fan Type: Case Fan Bearing Type: Sleeve RPM: 2300 RPM Air Flow: 31.62 CFM Noise Level: 26dBA Power Connector: 3 Pin Color: Transparent Compatibility: Case
Price: 9.99
