NZXT RF-AR120-B1 RGB LED AER RGB120 ADVANCED RGB LED PWM FAN FOR HUE PLUS - HUE PLUS IS REQUIRED TO FUNCTION AND SOLD SEPARATELY.
NZXT RF-AR120-B1 120mm RGB LED Aer RGB120 Advanced RGB LED PWM Fan for HUE+ (HUE+ is required to function and sold separately.) Type: Case Fan Bearing Type: Fluid Dynamic RPM: 500 - 1,500 RPM Air Flow: 17.48 - 52.44 CFM Noise Level: 22 - 33 dBA Power Connector: 4-pin PWM Compatibility: Case Dimensions: 120.00 x 120.00 x 26.00mm
Price: 29.99
© ® ™ 2017.
