NZXT RF-AR120-T1 RGB LED AER RGB120 TRIPLE PACK 3 X ADVANCED RGB LED PWM FAN FOR HUE PLUS NZXT RF-AR120-T1 120mm RGB LED Aer RGB120 Triple Pack 3 x Advanced RGB LED PWM Fan for HUE+ Type: Case Fan Bearing Type: Fluid Dynamic RPM: 500 - 1,500 RPM Air Flow: 17.48 - 52.44 CFM Noise Level: 22 - 33 dBA Power Connector: 4-pin PWM Compatibility: Case Dimensions: 120.00 x 120.00 x 26.00mm
Price: 76.55
