NZXT RF-AR140-C1 140MM RGB LED AER RGB140 AND HUE PLUS 2 X ADVANCED RGB LED PWM FAN WITH HUE PLUS CONTROLLER
NZXT RF-AR140-C1 140mm RGB LED Aer RGB140 & HUE+ 2 x Advanced RGB LED PWM Fan with HUE+ Controller Type: Case Fan Bearing Type: Fluid Dynamic RPM: 500 - 1,500 RPM Air Flow: 30.39 - 91.19 CFM Noise Level: 22 - 33 dBA Power Connector: 4-pin PWM Compatibility: Case Dimensions: 140.00 x 140.00 x 26.00mm
Price: 84.99
© ® ™ 2017.
