ROSEWILL 120MM CASE FAN WITH RED LED AND PWM - PULSE WIDTH MODULATION FUNCTION, VERY QUIET COOLING FAN FROM ADVANCED HYDRAULIC BEARING, MODEL RWCR-1612
Rosewill 120mm Case Fan with Red LED and PWM (Pulse Width Modulation) Function, Very Quiet Cooling Fan From Advanced Hydraulic Bearing, Model RWCR-1612 Type: Case Fan Bearing Type: Hydraulic RPM: 500 - 1,500RPM +/- 10%RPM Air Flow: 63.1 CFM Max. Noise Level: 6.9 - 26.2 dBA Power Connector: 4 Pin Color: Red Compatibility: Case
Price: 12.99
© ® ™ 2017.
