ROSEWILL RAWP-141209V2 - 120MM COMPUTER CASE COOLING FAN - SEAL IP56 DUST RESISTANT, SPLASH PROOF WITH PULSE WIDTH MODULATION - PWM SPEED CONTROL AND HIGH END TEF
Rosewill RAWP-141209v2 - 120mm Computer Case Cooling Fan - Seal IP56 Dust Resistant, Splash Proof with Pulse Width Modulation (PWM) Speed Control & High End Teflon Nano Bearing Type: Case Fan Bearing Type: Teflon Nano Bearing RPM: 500 RPM - 1500 RPM +/- 10% RPM Air Flow: 64.75 CFM Maximum Noise Level: 10 - 21.5 dBA Power Connector: 4 Pin Color: Black Compatibility: Case
Price: 10.99
© ® ™ 2017.
