ROSEWILL RFA-80WL - 120MM CULLINAN COMPUTER CASE COOLING FAN WITH LP4 ADAPTER - SEMI-TRANSPARENT FRAME AND WHITE LED LIGHTS, SLEEVE BEARING, SILENT
Rosewill RFA-80WL - 120mm CULLINAN Computer Case Cooling Fan with LP4 Adapter - Semi-Transparent Frame & White LED Lights, Sleeve Bearing, Silent Type: Case Fan Bearing Type: Sleeve RPM: 1200 RPM Air Flow: 41.9 CFM Noise Level: 23.2 dBA Power Connector: 3 / 4 Pin Color: Front side: Transparent frame Back side: Black frame Compatibility: Case
Price: 14.99
© ® ™ 2017.
