THERMALTAKE CL-F043-PL14SW-B RED-BLUE-WHITE-GREEN-LED OFF -256 COLORS LED CASE FAN
Thermaltake Riing 14 RGB Series High Static Pressure 140mm Circular RGB LED Ring Case/Radiator Fan - Triple Pack - CL-F043-PL14SW-B Type: Case/Radiator Fan Bearing Type: Hydraulic RPM: (Standard Mode) 800 ~ 1400RPM (Low Noise Mode) 600 ~ 1100RPM Air Flow: 51.15 CFM / 86.9 m3/h Noise Level: 19 dBA ~ 28.1 dBA Power Connector: 4 Pin Compatibility: Case
Price: 54.99
