THERMALTAKE CL-F049-PL12SW-A 256 COLOR - SOFTWARE SELECTED LED RIING 12 RGB PREMIUM EDITION SOFTWARE ENABLED CIRCULAR CASE - RADIATOR FAN
Thermaltake CL-F049-PL12SW-A 120mm 256 Color (Software Selected) LED Riing 12 RGB Premium Edition Software Enabled Circular Case/Radiator Fan Type: Case Fan Bearing Type: Hydraulic RPM: Software Controlled 500 - 1400 RPM Air Flow: 48.79 CFM Noise Level: 24.8 dBA Power Connector: USB 2.0 Header (From Controller) Compatibility: Windows 7 / 8 / 8.1 / 10 Dimensions: 120.00 x 120.00 x 25.00mm
Price: 81.61
© ® ™ 2017.
