THERMALTAKE RIING 12 HIGH STATIC PRESSURE 120MM CIRCULAR RING LED CASE - RADIATOR FAN WITH ANTI-VIBRATION MOUNTING SYSTEM - BLUE - 3 PKS
Thermaltake Riing 12 High Static Pressure 120mm Circular Ring LED Case/Radiator Fan with Anti-vibration Mounting System - Blue - 3 PKS Type: Case Fan Bearing Type: Hydraulic RPM: 1500 RPM (1000 RPM w/ LNC Cable) Air Flow: 40.6 CFM Noise Level: 24.6 dBA (18.7 dBA w/ LNC Cable) Power Connector: 3 Pin Color: Black Compatibility: Case
Price: 39.99
© ® ™ 2017.
