THERMALTAKE RIING PLUS 12 RGB TT PREMIUM EDITION 120MM SOFTWARE ENABLED CIRCULAR 12 CONTROLLABLE LED RGB RING CASE - RADIATOR FAN - TRIPLE PACK - CL-F053-PL12SW-A
Thermaltake Riing Plus 12 RGB TT Premium Edition 120mm Software Enabled Circular 12 Controllable LED RGB Ring Case/Radiator Fan - Triple Pack - CL-F053-PL12SW-A Type: Case Fan Bearing Type: Hydraulic RPM: Software Controlled 500 - 1500 RPM Air Flow: 48.34 CFM Noise Level: 24.7 dBA Power Connector: USB 2.0 Header (From Controller) Compatibility: Case Dimensions: 120.00 x 120.00 x 25.00mm
Price: 95.99
© ® ™ 2017.
